JD 450 stalling out?????
sosad
10-21-2003 12:45:05
my jd 450 keeps stalling out but has fuel....can someone tell me what the problem may be?
mike saxon
04-15-2006 21:39:08
 Re: JD 450 stalling out????? in reply to sosad, 10-21-2003 12:45:05
dirty fuel vaper locking air in fuel system
Gary Alford
11-21-2003 15:40:56
Jim gave you good advise, and also check the vent pipe. It is located under the fuel cap. It runs down to the bottom of the fuel tank. Try to blow air through it or run a length of welding rod through it. Some models had a screen in the shut off valve at the fuel tank.
jim
10-22-2003 11:14:09
CHECK THE FITTING ON TOP OF INJECTOR PUMP THAT THE RETURN LINE IS HOOKED TO,IF PLUGGED OR RESTRICTED IT WILL BUILD HEAD PRESSURE IN INJECTION PUMP AND SHUT OFF,THIS IS COMMON WHEN THE PUMP IS GETTING TIRED . ALSO MAKE SURE YOUR RETURN LINE IS NOT SHUT OFF.THIS THOUGHT WOULD APPLY AFTER YOU HAVE CHECKED FUEL IN TANK,CHANGED FUEL FILTER,AND MADE SURE TRANSFER PUMP IS WORKING
Jonathan
10-21-2003 17:25:35
how long does it run before it stalls.?? Has fuel where ??? in the tank ??? at the injection pump ??? Is there 12 volts at the wire going into the injection pump when it stalls ?? I know the internet is a wonderous thing...but ya gotta give us a little to go with !!! Have you actually done anything besides gotten out of the seat and scratched your head ???changed fuel filter etc... we need a little more info...
fredo.
10-21-2003 17:16:23
check for baer spot on wire from key to fuel pump. fredo.
