+ or - ground?
Frank
10-22-2003 08:17:24
I have a 1950 Int. TD-6 and am not sure if it is positive or negative ground. Can someone help with this before I toast another starter? Thanks
frank
10-22-2003 17:13:17
 Re: + or - ground? in reply to Frank, 10-22-2003 08:17:24
Thanks for all the info. I had been using one big tractor and implement battery hooking neg ground. I will hook pos with another battery when I get the starter back from the rebuild shop and give it a whirl. Thanks Frank
clark
10-22-2003 14:28:24
My TD-6 is pos ground. It also requires (2) 12 volt batteries that have atleast 950 cold cranking AMPS "EACH". low amps will cook a starter on these engines.
Bob/Ont
10-23-2003 07:50:21
 Re: Re: + or - ground? in reply to clark, 10-22-2003 14:28:24
Alot of people don't understand this Clark, but an electric motor is a short circuit untill it gets spinning. You need strong batteries and good cables to deliver the amps to keep the VOLTs up to spin it fast. Then the motor becomes a generator and resists the current flow. Low voltage and slow speed means high amps and a cooked starter very soon. Later Bob
R. Marg
10-22-2003 11:16:30
the TD6 I had was neg. ground but either way it won't hurt the starter as it will still turn the same way but it will kill the gen./alternator
Bob/Ont
10-22-2003 09:25:34
Any old IH's tractors or trucks I have seen where Pos. ground untill alternators came along. If you are frying starters, clean all terminals and check for voltage drop in the cables when cranking, should be half a volt per cable. Low voltage is more likely to be the problem than the wrong polarity. Later Bob
