TD 7 C won't move
shawn
10-22-2003 14:59:51
our td 7 won't move until you sit there at full throttle in gear for about fifteen minutes and then something inside engages and then itll work the rest of the day. has anybody else had this problem? we have replaced the charge pump and looked thru all the valves and havent found anything. its a powershift 3 speed
Jim
10-24-2003 19:11:31
 Re: TD 7 C won't move in reply to shawn, 10-22-2003 14:59:51
What is the drive shaft doing - if not turning or tunring slow you have a problem with charge pump or suction lines. If drive shaft is turning tru putting in gear - should stop till machine moves. I have torn down trans where the oring on the seperator plate in cluthc pack is so hard that it will not seal up until geats some heat in it.
