proper lube
Steve
10-25-2003 14:43:15
Here's another rookie question. The manual for the MF 200B lists the lube for the rollers/idlers as SAE 30. Realizing that the factory knows best I can't help but feeling that 30 is fairly light weight. Anybody care to offer an opinion of substitution of multi-purpose grease? Thanks
td-9
10-25-2003 18:08:08
 Re: proper lube in reply to Steve, 10-25-2003 14:43:15
on my old td-9s I Put 20/50 oil, if that leaks out quickly I add 90/140 gear oil, if that leaks out I fill with wheel wheel bearing grease. On these machines I am not going to spend time and money to replace bearings and seals on rollers. I feel some lube is better than running dry after 1 hour of work. I am not recomending this but it works for me. my machines will work till thay are not worth repairing, and them be used for parts for one of my other machines.
marlowe
10-25-2003 16:19:30
i know that's what the book says but the rollers are life time sealed. i have run them 3500 hr. and never lubed any. just watch for leaks
