350c turning problem
John Rogers
10-26-2003 16:13:34
I have a 350c dozer with wide tracks, and she will not turn either way. It runs good, and will drive farward and reverse, but it stop turning to the left and right. Any suggetions where to start looking for the problem?
Jonathan
10-27-2003 14:21:07
 Re: 350c turning problem in reply to John Rogers, 10-26-2003 16:13:34
It keeps going straight when you pull a lever ??? or it stops completely when trying to turn ???does it spin the tracks if pushing into a pile??
Steve
10-27-2003 04:41:42
third party image
John: If it will still push dirt then it's not the clutches.The problem probably lies in the brakes. Either they need adjusting or maybe replacing.
clark
10-26-2003 19:44:41
I would say that the steering clutches need adjusted.I am not sure how to adjust them JD's. or the clutches are worn out. It is probabley the later because the wide tracks would be harder on clutches than the narrow grousers.
