JD350 EZ start option
Polish Mike
10-27-2003 11:59:02
Does anybody have any info available on the factory installed ether assisted start option ? My JD350 has one, but there's no info on it in the shop manual I have. I'd like to know how it operates, and what kind of ether cannister it takes. Thanks !
Jonathan
10-27-2003 14:26:58
 Re: JD350 EZ start option in reply to Polish Mike, 10-27-2003 11:59:02
Do you have the electric solenoid activated style or is it just a neck that protrudes from the dash panel...I've only seen the latter neck type fitting on the dash on 350's. All thats required on that style is to remove the spray mozzle from the top of the ether can leaving only the small tube protruding from the can. That is inserted into the neck of that piece on the dash and it will release ether when the can is pushed in. just a little is needed...and check the tubing running to the engine...with age its usually broken somewhere
Bob/Ont
10-27-2003 12:56:16
Mike, the ones I have seen on machines take a cyl the same size as a small propane torch does. They screw on to the valve that gives the right amount of either to start the engine. It should be wired through a temp switch so it will not fire if the engine is warm. Later Bob
