JD 440 weight
kent
05-09-2001 13:30:22
Anyone know the weight of a JD 440? just need approx. lbs for hauling
kent
05-09-2001 14:51:39
 Re: JD 440 weight in reply to kent, 05-09-2001 13:30:22
It is pretty much stock....gas, blade, no cab
Sam
05-12-2001 19:24:31
 Re: Re: JD 440 weight in reply to kent, 05-09-2001 14:51:39
440IC-Approx. Shipping Weight - 5850 Pounds
440ICD-Approx. Shipping Weight - 6300 Pounds
63 dozer (inside mount manual angle & tilt) - 72" blade - 1189 pounds, 90" blade - 1264 pounds
64 dozer (inside mount 6 way Hyd) - 1600 Pounds
602 dozer (outside mount) - 1293 Pounds.
A gas 440 dozer with no rear attachments should not excede 7500 Pounds.
Jerri
05-10-2001 13:57:40
Kent,
You aren't making this too easy so I will just guess. OK gas machine will run about 6500 pounds. Now you do not specify "blade" so will assume dozer typed and not sure inside or outside mount so will guess about 1500 to 2000 pounds. I would say assume a minimum of 8000 pounds.
Jerri
Jerri
05-09-2001 14:16:16
Kent,
Is it a gas or diesel, does it have a blade and is it a loader or a dozer. Could run from a low of about 6000 lbs to about 12,000 lbs.
Jerri
