Is it worthwhile to rebuild my TD7 motor
Jeff
10-30-2003 20:22:07
I have an older TD7, that (except the motor) is in very good shape. The motor could use a complete rebuild, as the mains are starting to knock. I could probably sell it for what I paid for it, and then upgrade. So my basic question is whether its worthwhile to use the rebuild dollars to upgrade to a newer crawler, or just rebuild mine? \ thoughts or insight pls...
paul
12-21-2003 16:08:43
 Re: Is it worthwhile to rebuild my TD7 motor in reply to Jeff, 10-30-2003 20:22:07
Mains knocking on there engines is rare, you may be having a problem with the balancer, oil pan can be dropped and crank and balancer checked out easily in frame( without removing engine).
gm
11-01-2003 20:47:54
if you know the machine is in good shape, then rebuilding is great because then you know the engine is perfect. Getting another used machine, who knows what condition everything is in. -Greg
jeff
11-02-2003 13:38:14
 Re: Re: Is it worthwhile to rebuild my TD7 motor in reply to gm, 11-01-2003 20:47:54
thx! Kind of what I was thinking as well, although 6k to rebuild is a big pill to swallow... :)
ED
10-31-2003 04:54:02
I find it hard to believe you could up grade much with just the motor rebuild cost. If the rest of the machine is in that good of shape i bet hard to find one even as good for the money maybe your area of the country is different? Anyhow if you do rebuild email me i maybe able to save you money on rebuild kit
jeff
10-31-2003 19:52:47
 Re: Re: Is it worthwhile to rebuild my TD7 motor in reply to ED, 10-31-2003 04:54:02
check you remail...
