JD 1010C lever information
RO
10-31-2003 08:11:46
On a JD 1010C gas crawler, on the left side of the 'dash', there is a lever. The lever is stuck. Is this by chance the reverser lever? The levers on the right side of the dash are the throttle and the gear shift levers---correct? Thanks for any help.
fasteddy
10-31-2003 19:01:09
 Re: JD 1010C lever information in reply to RO, 10-31-2003 08:11:46
RO , when I had my 1010 crawler my lever would not move in the spring of the year after sitting out the winter. I removed the cable that goes from lever to reverser and soaked it over night in a penitrating oil. Worked good ever sense. Good luck!!!! Fasteddy , Don't use pumpkin oil!
ED
10-31-2003 15:33:19
That's what it is and your machine is an early one if shifter is in dash.. If you need any parts i have several for parts you can e mail me and i will send you link
