HGcrawler
DOUG
10-31-2003 15:21:12
Looking for the adapter to grease those buttons on the track off a HG. Thanks DOUG
Bill
11-01-2003 07:43:15
 Re: HGcrawler in reply to DOUG, 10-31-2003 15:21:12
Napa has the button head fitting filler head. They come in 2 sizes/measure before you purchase & you can pump the correct lubricant referenced below/next post down through a reasonably good/not antique & worn grease gun. Not the easiest or fastest way but low buck doable....
george md
10-31-2003 20:13:31
Doug, Any machine that has button head fittings is designed to be lubed with gear oil ( sae 90 or 140 depending on outside temp ), you will need to an alemite volume pump or something similiar. Those rollers have bushings that are fed oil thru a drip hole from a cavity around the outside of the bushing retainer. paste grease will not flow to the bushing and that will shorten the bushing life to near nothing . george
