TD8E Trans HELP!
Taylor Marret
11-02-2003 17:40:18
I bought a TD8E (1975) this past May and have run a tank and 10 gallons of fuel through it and the transmission has stopped working. it first slipped in F1 then will only try to move forward in r1 now. i have 160 main pressure that drops to 120 when you put it in any gear and 75 forward pressure and 75 reverse pressure. Any advice would be appreciated. I bought it as having a freshly rebuilt transmission if that helps any. Thanks Taylor
paul clement
12-21-2003 16:01:40
 Re: TD8E Trans HELP! in reply to Taylor Marret, 11-02-2003 17:40:18
your pressures are low, could be caused by an internal problem or bad seal rings in the collector housing on the end of the trans fwd/rev shaft.a good mechanic familiar with these can do a proper test and possibly save you a lot of $.
Rex
11-15-2003 14:52:52
If you need parts Try www.gearsinc.net or 270-622-8393
Jim
11-05-2003 17:12:04
Sounds like trans problems machine should not move forward in reverse ranges - sounds like forward pack is staying engauged. Could be pack is welded together from slipping or oring on seperator plate is bad. Main pressure should only drop 5 - 10 psi when in gear
JCmarleau
11-02-2003 19:42:18
I do have a Operator manual for this machine my e mail is jcmarleau@aol.com
Transamlew
12-01-2005 17:31:06
 Re: Re: TD8E Trans HELP! in reply to JCmarleau, 11-02-2003 19:42:18
I am also looking for a Transmission manual for the TD8E for my father. How do I find out what year and the S/N # for his TD8E. Any help would be appreciated.
Thank you for your time.
