Deas Plant.
11-08-2003 21:43:18
Re: Re: Re: Re: Re: Re: Recommendation on medium s in reply to Sean, 11-07-2003 08:08:03
Hi, Sean. Firstly, thank you for your kind comments on my posts. My way of looking at it this: I have worked for over 40 years all up to gather that information and experience. I am looking at retiring in about 8 months - at age 60 instead of the normal 65 here DownUnder - and if I can help other people get less skinned knuckles, egos or bank accounts by sharing that knowledge, it is worth my time and effort to do it. And I will continue to do so as long as people continue to make me feel like it is worth it. 941 Vs 951: The 951 is slightly larger and heavier and noticeably more powerful that the 941 but not up in the power league of the 955, although it was a fair bit 'nippier' than the the 955. I have no experience of the original series 951's. The 951B's did have some over-heating problems in some operating environments, in some cases to the point where they were a bit of a disaster in really hot weather. The 951C's were a totally different kettle of fish. The one my current employer had, you could NOT get it to get anywhere near over-heating. It eventually cracked a final drive housing. After welding it up twice and having it crack again, he welded it up a third time and traded it on a 941. This is NOT a common fault with the 951C's. I also suspect that, had I been allowed to weld it instead of being kept out in the field on a machine, it would have survived. This is not trumpet-blowing, just MHO. The 951's looked a lot more like the 941's that they did like the 955s and were noticeably smaller side by side, closer to the 941 in size than they were to the 955. The 951C's will use a fair bit more fuel in a day than 941's but you would be well and truly able to see the difference in the work done. It would be similar to the difference between the 943's and the 953's. I run a 953B which uses around 130 litres - approx. 35 gals U.S. - per day compared to the 943's at around 90 litres - approx. 25 gals U.S. - per day. The 953 will out-produce the 943 by anything up to half, even more in really hard going. You only have to put the two of them climbing the same hill side by side. The 953 will walk right away from the 943, either backwards or forwards. TimV has explained the 4-in-1 bucket pretty well in the post below. It IS worth bearing in mind in any dealings you might have with 4-in-1 buckets that they are NOT as strong as a standard/general purpose bucket. It pays to think about how what you are doing with a 4-in-1 bucket might be affecting the bucket and act accordingly. Because they are so versatile, they are well and truly worth looking after. Unless the mchine is fitted with a quick-coupler arrangement, neither general purpose nor 4-in-1 buckets are readily detachable. The difference is a bit like a T-handle and a single socket compared to the full socket box. If you want to e-mail me, I will send you a couple of photos showing 4-in-1 buckets compared with general purpose ones. Or you can click on the link below, select 'Used Machinery', wait for the page to refresh, select 'Loaders', wait for the page to refresh, in 'Sub-Type', select 'Crawler Loaders' and 400 in 'Number Of Records' and browse the results. You will see a wide range of different makes and models of track loaders and a mix of general purpose and 4-in-1 buckets. Have fun. Hope this helps. You have a wonderful day. Best wishes. Deas Plant.
