1947 TD7
dewey
11-10-2003 15:41:52
my eng. runs fine on gas but on diesel number 4 cyl. won't fire I check compression on the gas side it holds at 120psi. so i assume the valves are good. any help would be appreciated
old
11-10-2003 15:54:32
 Re: 1947 TD7 in reply to dewey , 11-10-2003 15:41:52
pull that injector and have it checked its probably bad, since it runs on all the rest it almost has to be the injector. Hope this help you
dewey
11-12-2003 15:17:50
 Re: Re: 1947 TD7 in reply to old, 11-10-2003 15:54:32
had all injectors check there good. its a puzzle
old
11-12-2003 16:37:26
 Re: Re: Re: 1947 TD7 in reply to dewey, 11-12-2003 15:17:50
Well if all the injectors are good then it has to be valves, piston, compression. What type of compression do you have on that cylinder in the diesel side. Or maybe the fuel line to that cylinder is clogged
