Case 480ck
Lloyd Byrne
11-10-2003 15:53:42
Can any one help me figure out the problem that I'm haveing with my 480ck it jumps out of low range?
Steve Schmittgens
11-12-2003 13:31:26
 Re: Case 480ck in reply to Lloyd Byrne, 11-10-2003 15:53:42
Lloyd, the low range gear in your tranny is square cut & has a shift collar over it. Usually, after the years the leading edge rounds off & the collar doesn't have a sharp edge to grab. Hence when under a heavy load or when you back out of the throtle hard it jumps out of gear. (very similar to the synchronizer problems you'll run into.) Steve
JCMarleau
11-11-2003 05:21:58
Most likely one the gear is missing a tooth might be able to help with used part or with parts manual my e mail is jcmarleau@aol.com
