Hydraulic System Question
Brad
11-12-2003 09:58:31
I have a Cat D5H and have removed several hydraulic cylinders due to broken bearings/pins that hold them on. When removing the cylinders there was lots of fluid loss, leaving the cylinders full of air, do I need to bleed this air out somehow, or will the hydraulic system handle this through normal use.
Len Sholes
11-12-2003 10:06:49
 Re: Hydraulic System Question in reply to Brad, 11-12-2003 09:58:31
Hello Brad, no it is not necessary to bleed the hydraulic cylinders all you have to do is to make sure the hydraulic tank is at the full mark and then cycle the cylinders full travel in both dirctions a number of times and then check the oil level again and top it up. Do not fill it to the full mark as the oil expands when it gets up to operation temperature.
Brad
11-13-2003 08:43:02
 Re: Re: Hydraulic System Question in reply to Len Sholes, 11-12-2003 10:06:49
Thanks for the help.
