ford 550 backhoe
terry
11-12-2003 19:29:34
help! we have a ford 550 backhoe in which one tire froze up while using. i was able to release it by driving in reverse. this worked 2 or 3 times and then it didn't work anymore. i am attempting to remove axle and housing. i have taken off bolts and wheel and i cannot get the housing off. could this be a two part axle? is there a seal that needs to be broken? can anyone give me any ideas as to why this won't slide out? thanks, terry
Alvin n Ms.
11-13-2003 07:57:51
 Re: ford 550 backhoe in reply to terry, 11-12-2003 19:29:34
Terry, the IT manual says just remove cap screws from retaining axle housing to center housing then remove assembly from tractor. It may have some dummy holes with threads, if so you can screw some bolts in and push the housing away from the center. look close you may be overlooking something.
