Cat 977L, pressure in hyd reservoir.
Alvin n Ms.
11-13-2003 08:07:01
When I take the cap off of the hyd/tank, it seems to be under lots of pressure. Is that normal? Thanks alvinnms
Brokenwrench
11-13-2003 08:29:35
 Re: Cat 977L, pressure in hyd reservoir. in reply to Alvin n Ms., 11-13-2003 08:07:01
This is normal. It is a sealed system and as the fluid expands from heat it builds up pressure.As a side benefit this also helps keep the pump charged with oil when operating.
Alvin n Ms.
11-13-2003 08:37:28
 Re: Re: Cat 977L, pressure in hyd reservoir. in reply to Brokenwrench, 11-13-2003 08:29:35
Brokenwrench, I want to thank you and have a great day. I know that I'm going to catch a lot of flak about a 450JD post. nxtime alv
