td-18 trans
king of obsolet
11-13-2003 19:54:23
just working on my td-18 i just got (boy is it bigger than the td-9) what is the short lever beside the gear shift and what does the rod from the clutch lever doing going to the gears on top of the trans, thanks
Gary Mckenzie
11-14-2003 13:59:56
 Re: td-18 trans in reply to king of obsolete, 11-13-2003 19:54:23
The short lever is probably the hi-lo shift, mine is the same length as the gear shift lever. The linkage connected to the clutch lever is a locking mechanism that prevents shifting (or jumping out of) gears while the clutch is engaged. This can lead to real excitement when the clutch lever breaks below the floorboard and you are operating in close quarters, but that's another story...
jim/pa
11-14-2003 10:04:23
on my td-14 theres a rod that goes to the transmission brake. the lever is hi-lo shifter. anyone need td-14 parts? engine is whooped, but runs, rest of machine is fair. i'm in northeast pa
RO
11-14-2003 05:43:56
I believe the short lever you are referring to is the Hi-Lo shift lever for the transmission. I'm not familiar with the clutch lever rod you are referring to.
king of obsolete
11-14-2003 17:35:04
 Re: Re: td-18 trans in reply to RO, 11-14-2003 05:43:56
i thank you guys for the info, will start a new posting for more questions i have. thanks
