buzzing in hydraulic system
Dominic
11-14-2003 03:53:52
I have a international 460 utility with loader and backhoe attachment. was working fine now at anything above idle my hydraulis sytem starts buzzing loudly and i loose hydraulic power. could my hydraulic pump be getting weak. any help would be greatly appreciated.
Charlie
11-14-2003 06:27:32
 Re: buzzing in hydraulic system in reply to Dominic, 11-14-2003 03:53:52
The first thing I would check is the hydraulic filter or any other source of obstruction between the reservoir and the pump. I get a noise out of my pump when the screen around the filter clogs up with misc. scum and junk., and hence not enough fluid is getting to the pump. I have a different machine, a TD340A, but the principle should be the same.
Dominic
11-14-2003 17:21:07
 Re: Re: buzzing in hydraulic system in reply to Charlie, 11-14-2003 06:27:32
thanks. i checked the hydraulic filter housing and found that the cork gasket for the cover was causing a suction leak. i replaced the gasket and now is working fine.
