Kom. D31s-16
John
11-14-2003 21:54:14
What year ranges are the D31s-16 Komatsu built. I believe I have a found a good loader. Anyone know of problems on these machines? Steers well, but the left pedal steer has to be pulled back once you turn? Owner says will fix before I buy. Pins seem loose that holds the bucket on is this a cheap fix? Thanks, JT
crawler
11-15-2003 03:21:30
 Re: Kom. D31s-16 in reply to John, 11-14-2003 21:54:14
I own a d31s-Q mine is around a 1980. It is the sweetest track loader, I really like it have had zero problems. The pins are probly wore out and need replaced, or the bushings need to be replaced. It shouldnt be to bad, but I would get them tight so you dont wear through the bushings and oval out the frame.
