How to, BD2G Hydraulic Pin Lubrication, Mitsubishi
Bman
11-17-2003 14:12:44
I've a 1986 BD2G crawler dozer. Will anyone help me understand how to grease the the hydraulic ram connecting pins? I see the manual says three pumps of grease, but there are no apparent fittings.
JimInOz
11-17-2003 17:10:03
 Re: How to, BD2G Hydraulic Pin Lubrication, Mitsub in reply to Bman, 11-17-2003 14:12:44
Make sure that your book is matched to the serial number of the machine.My 88 model is excellent,grease fittings are accessed from side-on position.If you've got dirt build up,clean it off & occassionaly wash the fittings clean.Good little dozers.
John
11-21-2003 18:41:41
 Re: Re: How to, BD2G Hydraulic Pin Lubrication, Mi in reply to JimInOz, 11-17-2003 17:10:03
Does anyone know the best way to get the plugs out of the final drive housing to check the oil? My book says to remove the top plug. The grease fittings on part of my 1987 BD2G a broke off, but the ones on the blade actuators are recessed andas Jim said they go straight on. john
JimInOz
11-22-2003 00:41:34
 Re: Re: Re: How to, BD2G Hydraulic Pin Lubrication in reply to John, 11-21-2003 18:41:41
Loosen top plug with ratchet or socket bar....3/4 drive I think.Let book be your guide. Broken grease nipples can be removed with small metric socket. Rhine Equip in Tacoma are support agents.
