Dresser TD -7 Head - C series / D206 / powershift
Conanian
11-19-2003 17:53:40
I have noticed that the waterjacket ports in the block do no line up with the water ports in the head on the left side. The head gasket is cut out for the water ports and lines up with the block, however it it will not allow water to pass on the left side of the block to the head. I see there is pleanty of meat around the water ports in the head to drill the head to allow water to flow. Is this something that is common amoung Dresser Dozers? Will there be any problem with the drilling of new holes?
Mike
11-22-2003 13:54:16
 Re: Dresser TD -7 Head - C series / D206 / powersh in reply to Conanian, 11-19-2003 17:53:40
They are blocked off for a reason. If you drill them out the waterpump will just keep circulating the water in the block and head and not through the radiator.
