Cat D6 9U brake bands
Big Ed
11-20-2003 10:58:44
Dose any one know if the there is a way to remove and replace the three piece brake bands with out removeing the hole drum assemble. Ive removed the right side band but had to used a torch. We could not rotate the band enough to reach the last set of bults. there must be a better way, any help would be nice. Big Ed.
clint goodson
12-22-2003 07:57:57
 Re: Cat D6 9U brake bands in reply to Big Ed, 11-20-2003 10:58:44
Bob is right about the support bolts. Also you need to make sure that the adjustment is backed all the way out. remove the back cover and remove the nuts rotate each section of the band until you have removed each. It is not very easy to put back but being very patient it will work.
Bob/Ont
11-20-2003 13:21:59
Ed, dry clutches have supporting bolts to hold the bands up off the drum, have you loosened them off. They are tightned right up then backed off only a turn and a half, they might be holding the band from turning. Later Bob
Big Ed
11-20-2003 19:29:23
 Re: Re: Cat D6 9U brake bands in reply to Bob/Ont, 11-20-2003 13:21:59
Bob: your my hero, I set there lying on my back starring at that supporting bolt and I never did put it together. loosining the supporting bolt should make putting things go back together a lot smoother. thanks Bob
Mickers
11-27-2003 07:59:32
 Re: Re: Re: Cat D6 9U brake bands in reply to Big Ed, 11-20-2003 19:29:23
There is an old boy near my hometown that can replace the bands through the back hole! I have seen him do it on our 9U
