skid steer loader died and will not move.
tim rewis
11-20-2003 17:12:29
bobcat 720 skidsteer loader was running fine then just died while moving and now will not turn over and the wheels are locked I cannot tow it either I can only drag it how do i disengage or fix
brokenwrench
11-22-2003 13:50:02
 Re: skid steer loader died and will not move. in reply to tim rewis, 11-20-2003 17:12:29
You are going to have to drag it CAREFULLY. With a hydrostat,it locks up when there is no oil pressure to it. There is no easy way to disengage the drives short of dismantling the final drives and removing the chains.Your best bet would be to fix the engine where it sits,or pull it up on a trailer or rollback and take it to the shop
tim rewis
11-23-2003 11:39:02
 Re: Re: skid steer loader died and will not move. in reply to brokenwrench, 11-22-2003 13:50:02
Im not sure if the drive is locked up or the engine I think it is just the drive that is locked up the engine was running fine before this. the unit was running for about five minutes when it died I dont understand why the drive is locked up and the engine I cannt turnover motor.
Brokenwrench
11-24-2003 13:16:39
 Re: Re: Re: skid steer loader died and will not mo in reply to tim rewis , 11-23-2003 11:39:02
Even if the motor is tied up or not, the drives will not turn. It is possible that the pumps siezed,causing the engine to act like its locked up. Even with the engine out of the machine,the wheels will not turn,its the nature of a hydrostat machine.
Carsten
11-21-2003 08:47:36
I am curious about that too. I the manual for my 773 it states that you are only supposed to drag it a very short distance, 25 feet I think it was. They show a crane being used to move it. There has to be a way of disabling the parking brake etc. Some of the places I use my Bobcat you would not be able to get a crane close to.
