fiat allis 16B
roger
11-22-2003 19:17:03
i am having probs with the steering,it dose'nt want to turn when its cold,once it warms up it works fine.have tryed adjusting the steering valve,but not sure what i am doing,any help would be graet thanx
paul clement
12-21-2003 15:31:10
 Re: fiat allis 16B in reply to roger, 11-22-2003 19:17:03
basic test for steering: pull both levers back in fwd, machine should stop. let one off, machine should move. pullit back again it should stop. do the other lever the same way. this tells you if steering cluthes are driving. if both drive, then problem is the brake is not holding, brake must lock up allowing the opposite sideto drive dozer around turn. loose brakes are much the most common problem, must be adjusted thru a cover on top of the steering cluth compartment
sherzaman
04-11-2004 12:03:58
 Re: Re: fiat allis 16B in reply to paul clement, 12-21-2003 15:31:10
hello i want fiat allis 16b 1. work shop manual 2.operators manual
3.parts manual
please if u kindly find those books for me i wil buy it and then i think i will solve my prob after readings those books please help i am stuck up .
Ken
11-29-2003 19:13:07
Check the steering pump mounted on the left side of the converter housing. Its a small alumium pump with 2 steel lines on it. Also check the suction side fittings on the pump, in the past I have found them to come loose & suck air when they are cold, once it heats up it seals itself off.
SHERZAMAN
04-11-2004 11:59:57
 Re: Re: fiat allis 16B in reply to Ken, 11-29-2003 19:13:07
HI I AM IN A VERY BIG TROUBLE DUE TO SOME FAULT IN THE TORQUE OF MACHINE FIAT 16B BECAUSE THE MACHINE IS NOT GAING IT'S FULL POWER UNDER LOAD SO IF U KINDLY GIVE ME THE 1.OPERATORS MANUAL 2.PARTS MANUAL 3. WORK SHOP MANUAL .I WILL BUY ALL THESE BOOKS PLEASE IF U KINDLY SEND ME AN EMAIL ABOUT THE PURCHASE OF THOSE BOOKS I WILL BE VERY GREAT FULL TO U .
