Bobcat 610 Leaks
Steve
11-23-2003 16:06:46
I have a bobcat 610. Problem is when using the high speed the half shaft on the left side where the drive belt is leaks quite severly. I've checked the jackshaft housing and bearing and all seems to be O.K.I replaced the sealing washers and gasket on the inside of the bearing housing and no luck. Any suggestions??
KENO HENDERSON
11-27-2003 09:05:32
 Re: Bobcat 610 Leaks in reply to Steve, 11-23-2003 16:06:46
Hi Steve Sorry I didn't read your post close enough. I have not had a leak in that spot (Yet). Maybe you could repost your question?. keno
KENO HENDERSON
11-24-2003 16:47:24
Hi.Steve I also have a 610 bobcat.Have many hours on that varable speed drive.sh---.Bobcat sells a seal kit to fix your problem.I have a parts manual at work.I'll be glad to get parts #s for you if you still need it?.E-mail me Keno henderson
Charlie
11-25-2003 06:22:19
 Re: Re: Bobcat 610 Leaks in reply to KENO HENDERSON, 11-24-2003 16:47:24
Given your familiarity with this, let me ask a related question. Recently, when I push the lever forward to go into high speed, the variable sheave moves together mcuh faster than previously, almost instantaneously, and causes the engine to stall. Have you got any experience or thoughts on this? Thanks.
KENO HENDERSON
11-25-2003 17:12:48
 Re: Re: Re: Bobcat 610 Leaks in reply to Charlie, 11-25-2003 06:22:19
Hi Charlie See the parts list I gave Steve in this thread. You need the same parts.Replace them even if they look new.This should also fix your machine.Let me know how it goes?. Keno Henderson
Steve
11-24-2003 17:11:33
Yes I would appreciate that as I want to get this fixed before the bad weather hits up here.
KENO HENDERSON
11-25-2003 17:05:47
 Re: Re: Re: Bobcat 610 Leaks in reply to Steve, 11-24-2003 17:11:33
Hi Steve Hope this helps.Here is a list of parts you need. (1) 6515886 seal wiper (1) 58k000216b o-ring (1) 58k000325b o-ring (1) 888670b Guide (1) 25k020005b o ring (1) 6516301 seal (1) 6516312 bearings (2) Ask for a figure c23-variable speed drive sheave Drawing and parts list.(picture is worth every dime.)Replace every one of these parts.Even If they look good.Let me know how it goes. Keno Henderson
Steve
11-29-2003 04:45:35
 Re: Re: Re: Re: Bobcat 610 Leaks in reply to KENO HENDERSON, 11-25-2003 17:05:47
Hi Keno, I replaced the bearing,housing,shaft and the sealing washers and gasket and all is o.k. now.There must have been too much clearance somewhere.
KENO HENDERSON
11-29-2003 17:33:30
 Re: Re: Re: Re: Re: Bobcat 610 Leaks in reply to Steve, 11-29-2003 04:45:35
Hi Steve Glade to here you got it fixed.I know it feels good.lol! Keno
Steve
11-26-2003 04:47:11
I believe these parts are for the variable sheath on the motor side. Correct? Mine is leaking on the other end where that half jackshaft goes into the side of the machine where the chains are. There is a bearing and housing and 4 sealing washers.
