manuel clutch adjustment d20 komatsu
ray
11-27-2003 18:54:40
anyone ever done direct driveshaft brake band adjustment that I believe works in conjunction with the clutch release pedal,mine seems to be freewheeling too long which causes gear grinding when changing rapid front/back directions.
JimInOz
11-29-2003 20:40:58
 Re: manuel clutch adjustment d20 komatsu in reply to ray, 11-27-2003 18:54:40
First thing.....buy an operator manual.It pays for itself over & over.My Mits BD2G book says it needs 2.5 secs to stop at full revs,but a short pause at neutral always does the job.Also,if it's low houred,you really have to be right in the gate when shifting.Treat it good & it'll do likewise!
ray
12-04-2003 19:27:31
 Re: Re: manuel clutch adjustment d20 komatsu in reply to JimInOz, 11-29-2003 20:40:58
thanks jim,you all have been a lot of help getting the bugs worked out until I get my owners manuel. The reason I was curious when I had the floorplate off I noticed this brake band type thing around the driveshaft that I figured was linked to the clutch linkage to help bring the machine to a stop to shift without gear grinding so much. I think the d-20 komatsu is a well built machine. Ray
