Case 310 Mechanics
Brad
11-30-2003 12:27:59
I have a Case 310 which recently started making a noice in reverse, and won't go in first. When trying to go forward in first, the engine bogs down like the brakes are on. The other forward gears work fine. Also, the right steering brake isn't working now. I'm not a mechanic, but I am mechanically inclined. Is there anyone within the states surrounding Indiana that would be willing to work with me to get my 310 fixed? Please e-mail me and we can discuss the details. Thanks Brad
lloyd
04-05-2004 07:43:02
 Re: Case 310 Mechanics in reply to Brad, 11-30-2003 12:27:59
Brad i have the same problem. i rebuilt transmission myself but less than 50 hours it's doing it again. What did you fine out that i may have over looked. .Need help
Joe Giordano
12-02-2003 05:48:01
I have a tranny for that machine if you you end up needing a tranny. Email dozerjoe@yahoo.com or call me at 717-533-6199 I am in Hershey Pa
jim/pa
12-03-2003 03:48:52
 Re: Re: Case 310 Mechanics in reply to Joe Giordano , 12-02-2003 05:48:01
i rebuilt my 310g transmission this past summer. first and reverse have one thing in common, the reverse gear shaft, which rides on burrless bearings. it could be that your bearings are out enough that the first gear, is binding. you have to remove the transmission to get to the shaft, it comes out thru the differential case. you'll need a machine shop to build you a new shaft, and the bearings are standard off the shelf size. the case also wears where the shaft goes thru, so you may need to fix that also. i dont have a parts or repair book, i was just winging it, but its fairly straight forward mechanical stuff. figure a couple weeks downtime for this job. you can call me for more details if you want, #570-746-1379. good luck
