JD 350-C turning brake Question
David
12-01-2003 13:17:25
After adjusting the turning brake on my 350C dozer, I can work about 5 to 10 minutes and the self-adjusting mechanism will tighten it up so that the brake begins to grab the drum before the clutch disengages. What can I do to keep the adjustment so that it does not tighten up too far by itself? Any help will be appreciated.
jdemaris
12-01-2003 14:10:04
 Re: JD 350-C turning brake Question in reply to David, 12-01-2003 13:17:25
I was working for a JD dealer when the C series came out, and we had a miserable time with the self-adjustors on the brakes tightening up all the time. We unhooked them on all our rental machines. It's been a while since I worked on them, though. Seems Deere must have fixed the problem by now.
Roy
12-01-2003 21:25:04
 Re: Re: JD 350-C turning brake Question in reply to jdemaris, 12-01-2003 14:10:04
I know a 450-c has a bolt that limits the travel on the self adjuster..The 350 must also have the same arrangement to limit adjuster, but i don't remember for sure..If you find it turn it in a half turn at a time and try it
David
12-02-2003 07:08:04
 Re: Re: Re: JD 350-C turning brake Question in reply to Roy, 12-01-2003 21:25:04
Thanks for the information. I will disconnect the self adjusters.
