Td9 injector help??
Mark
12-04-2003 14:13:45
I was wondering if the injectors are the same or close enough on a td9 1954 model and a td9-91 1957 model. I have one that seems to be breaking down at high idle causing a missfire, under load it runs fine. Or is it possible to clean the injectors? Or does someone have some 91 series injectors for sale cheap? Thanks Mark
Jumpedthetrack
12-04-2003 22:50:45
 Re: Td9 injector help?? in reply to Mark, 12-04-2003 14:13:45
Why dont you get them rebuilt?There is not much to them and any good diesel repair shop could do it.You also might check to see if the timing on the injector pump might need advanced.If you have a manual,it will show you how.
