IHC TD 20 Part needed
RAR/IA
12-04-2003 18:20:29
Suction screen, 310 897 R91, has failed in the hydraulic system. Screen is torn up bad in an area about the size of a mouse. Why??? No parts at dealer as number is obsolete. Any ideas on where to find? Could also use o-rings, 352 313 R1 and 301 913 R1. Some debris on remaining screen. Hydraulics were getting slower with time. Also had to raise blade and scarifier with another tractor and they stayed up. Believe debris is in relief valve (where is it located? Is it the one with adjusting screw) or pump is badly worn. Any words of wisdom? Thanks for previous help in locating screen on tractor! Roger
Taylor Lambert
12-05-2003 09:30:25
 Re: IHC TD 20 Part needed in reply to RAR/IA, 12-04-2003 18:20:29
I have a neigbor with a load of TD20's for parts, Ill Check with him in a few days when get comes in.
RAR/IA
12-05-2003 15:45:28
 Re: Re: IHC TD 20 Part needed in reply to Taylor Lambert, 12-05-2003 09:30:25
Thanks for the reply. The screen in question is at the left lower end of the radiator support. It is held in with two small straps with a 3/8" bolt in each. The screen area is 13" long with a circle of steel with an o-ring groove in each. Hope this helps. There are a couple of styles. Where are you and your friend located. This tractor is in SE Iowa. Roger Russ
Taylor Lambert
12-05-2003 21:35:01
 Re: Re: Re: IHC TD 20 Part needed in reply to RAR/IA, 12-05-2003 15:45:28
Roger we are located in northeast Mississippi. What yoer is your machine if we dont have it there is a guy in wyoming that has a few TD20s ill have to get his address at work
RAR/IA
12-06-2003 07:39:44
 Re: Re: Re: Re: IHC TD 20 Part needed in reply to Taylor Lambert, 12-05-2003 21:35:01
I do not know the year. Will get the serial number Monday and repost. Thanks, Roger
RAR/IA
12-07-2003 16:47:58
 Re: Re: Re: Re: Re: IHC TD 20 Part needed in reply to RAR/IA, 12-06-2003 07:39:44
Serial number plate has all writing obliterated except for stamped numbers: TD20 (twice) 1690 3681 Do not know which is the serial number. Roger
