Cat D2 steering help
Donnie
12-05-2003 16:52:14
I need some info on how to seperate the final drives from the transmission I can't get the cover off and there appears to be 4 more bolts on the inside what am i doing wrong? thank you Lowboy E mail is Lowboy@egyptian.net
Doug
12-07-2003 17:58:28
 Re: Cat D2 steering help in reply to Donnie, 12-05-2003 16:52:14
Removed the final drives from my D25U. After removing all the bolts that go around the case cover we used chisels to seperate them from the tractor. They were on pretty tight but once started they came off quickly. If the steering clutches are rusted onto the drum it will be harder to remove. There are dowles that hold the final case onto the tractor these most likely are the bolts on the inside you see. Hope this helps, Doug
