does any one own a td-9 series b
darryl
12-09-2003 20:06:42
just wondering if anyone else has one would like to talk to a liitle bit
Davey
12-10-2003 20:45:03
 Re: does any one own a td-9 series b in reply to darryl, 12-09-2003 20:06:42
Mine is a 1964 model, Give us your serial number and someone will chime in with the age of your machine. Mine has been good but I nurse the head. Long warm up and at least 10 minutes to cool down at a low idle. Is yours powershift or gears and what problems have you got?
darryl
12-10-2003 21:31:51
 Re: Re: does any one own a td-9 series b in reply to Davey, 12-10-2003 20:45:03
get back to you with s/n power shift i guess the only problem i have had is with torque converter area. first the straps broke caused a bad leak then they broke again the second time i had mechanic to make a plate to blolt between instead of straps. that worked good but now the machine has quit pulling and the drive gear for the trans will free spin. i love the work the machine will do and the engine runs like a sewing machine. very strong for its size and everything else seems to be fine. it just cost me alot of money to have it worked on. so i was looking for other owners to tell some things so i can figure out whether i should mees with it or not. i wish i had the equipment to work on it myself i believe it would be an easy fix if i could handle the tear down and reaasembly. thanks
darryl
12-10-2003 21:31:24
get back to you with s/n power shift i guess the only problem i have has is with torque converter area. first the straps broke caused a bad leak then they broke again the second time i had mechanic to make a plate to blolt between instead of straps. that worked good but now the machine has quit pulling and the drive gear for the trans will free spin. i love the work the machine will do and the engine runs like a sewing machine. very strong for its size and everything else seems to be fine. it just cost me alot of money to have it worked on. so i was looking for other owners to tell some things so i can figure out whether i should mees with it or not. i wish i had the equipment to work on it myself i believe it would be an easy fix if i could handle the tear down and reaasembly. thanks
Davey
12-10-2003 13:05:08
Yes Darryl I own a TD9B, gear drive which I gather is a bit rare compared to powershift models. It is Turbo 282 whereas the powershift is not. What do you want to talk about or are you having problems?
darryl
12-10-2003 20:20:53
 Re: Re: does any one own a td-9 series b in reply to Davey, 12-10-2003 13:05:08
well mine is not a turbo it sounds like yours maybe a later model. yes im having problems but i was wanting to talk to other owners to get a feel on thier opinion of the machine trying to decide whether to fix it or sale it.
king of obsolete
12-10-2003 07:23:23
about what year would that be??? i own 5 td-9s and you can check me out at Link thanks
bcPA
12-11-2003 07:56:06
 Re: Re: does any one own a td-9 series b in reply to king of obsolete, 12-10-2003 07:23:23
went to your site and spent some time looking and learning. nice site. Only I was disappointed because I did not see any TD9 pictures.
king of obsolete
12-11-2003 08:21:32
 Re: Re: Re: does any one own a td-9 series b in reply to bcPA, 12-11-2003 07:56:06
sorry about that, the fellow whosite it is changed things around. check out this sites for td-9 pictures of mine Link http://redpowermagazine.com/cgi/yabb/YaBB.cgi?board=news Link http://www.acmoc.org/Index.htm there that should give you lots of ih cats, there is not many places to chat about ih cats, thanks and just look for the king's name
darryl
12-10-2003 20:20:54
i think it is early 70's
