JD 440 Brake Band Issue
Terry
12-13-2003 12:12:26
The lefthand brake band appears not to be totally on the drum at the bottom of the drum area. I have tried to move it over with little success. How difficult is it to get to the band and replace it. does the rear sprocket and housing have to be removed.
ralph
12-15-2003 10:21:49
 Re: JD 440 Brake Band Issue in reply to Terry, 12-13-2003 12:12:26
terry don't be afraid to jump in it--if you need any help between myself,lavoy, ed we've done a couple hundred. just ask. ralph
Bob
12-14-2003 20:40:40
Terry, DON'T start this without a manual.....
Ed
12-14-2003 14:40:52
see it all the time have to be careful when putting finals on Have all and any parts for that you would need
Lavoy
12-13-2003 16:45:12
I have seen this happen a few times. The band is up on top of a tab that is supposed to keep it in place. It happens when the final is installed, and the drum pushes the band out of place. Usually it will cut the band in two. Lavoy
RALPH
12-13-2003 14:47:01
yes the tracks-sprocket and final drive have to come off. ralph
JD dozer mike
12-13-2003 17:55:53
 Re: Re: JD 440 Brake Band Issue in reply to RALPH, 12-13-2003 14:47:01
YEAH it's a BIG phreakin job, may as well wait till it won't steer anymore.
ralph
12-13-2003 18:02:46
 Re: Re: Re: JD 440 Brake Band Issue in reply to JD dozer mike, 12-13-2003 17:55:53
it takes me about 2 hours to take apart. i've done 100 or so-if you need parts let me know. ralph
Doug Tonner
01-03-2008 14:59:49
 Re: Re: Re: Re: JD 440 Brake Band Issue in reply to ralph, 12-13-2003 18:02:46
Ralph,
My name is Doug Tonner and have just torn apart a JD 440 and I have the brake bands off but got a quote of $1000.00 for both sides of the brakes. It does not look like there really is that much material to be worth that much money. Please let me know if you have any information on where to get these parts for a lot cheaper. Thanks a lot,
Doug
