D2 Steering Clutch Adjustment
Elton
12-24-2003 16:46:28
I know that the steering clutch adjustment is done by adjusting the fine threaded bolt under the access cover just behing the shift lever. But what I was wondering was if the lower part of the clutch fork also was adjustable from under the bottom of the cat. There is two plugs underneath the clutches. Are these access holes to the bolts or are the drains for the clutch housing? The d2 in question is a 5U series. I have a D6 2H series that has these adjustments underneath so that you can gain more clutch action once the top adjuster is at its limit. One side is fine but the other side is almost at its max. This tractor is one that I am looking at buying and I'm not sure how bad the clutch is. The tractor has been sitting for 8 or more years. I wonder if someone pulled back on the clutch and bent some linkage or something. any info. please.
