Case 1150D?
brian
12-26-2003 12:32:53
My used crawler guide doesn't mention this machine. Are there pros/cons, weight, HP, engine, etc? Many Thanks.
Steve Schmittgens
12-31-2003 12:52:40
 Re: Case 1150D? in reply to brian, 12-26-2003 12:32:53
Brian, The 1150D dozer has a Case A504BD engine (turbo optional). It generates SAE gross HP 125 & Net HP 110. The machine weighs approximately 24,000LBS. The machine has counter-rotating tracks, they were fast, had multiple steering options, & were relatively easy to work on. If you have any other questions call me @ (314) 966-6692. I worked for Case for 25 years & can give you more info if you need it. Steve
Steve Osborn
12-06-2004 08:20:06
 Re: Re: Case 1150D? in reply to Steve Schmittgens, 12-31-2003 12:52:40
I am looking for a dozer to clear farm land with. I have 3 locations and need to haul this dozer to each location. The land that I need cleared is mostly underbrush with smaller trees, maybe 6 to 7 inches in diameter. Then need to pile the brush to burn. My question is what is the best dozer for this type of farm work? Sure would appreciate your feedback. You seem to know what you are talking about.
mark
12-30-2003 16:17:14
Your 1150 will be arond 94 HP and about 17000 lbs. If your looking for another one call me at 204 585 2406 or Email me
