T340 dozer
ron
12-26-2003 17:26:08
I have a t340gas 1959 or60 the motor smokes bad my brother has an industrial300 backhoe about same year it has a diesel 4cyl.The hood and dash sheetmatal gauges all match mine the radiator the hydri.pump all the same.I measured the blocks the both are 23inches long does any one know if i can put the diesel in the dozer the backhoe has had numbers removed because we can't find them the loaders a wagner and so is the backhoe need help also what cu.in.is the diesel that is in the T340 d is it the same one that is in any of the tractors?
DAN MILLER
12-26-2003 19:11:12
 Re: T340 dozer in reply to ron, 12-26-2003 17:26:08
THE T340 HAS A C135 ENGINE. THEY USED IT IN THE 330, 340, 404, 2404 TRACTORS-T340 AND T5 CRALLERS ALSO THE 91 COMBINE.IM NOT FAMILIAR WITH THE 300 BACKHOE BUT THE TD340 USED A D166 ENGINE. IT IS ALSO USED IN THE 330 AND 340 TRACTORS. DAN'S TRACTOR PARTS
ron
12-26-2003 19:22:18
 Re: Re: T340 dozer in reply to DAN MILLER, 12-26-2003 19:11:12
Thank you very much Dan,what kind of parts do you have for at340 or the diesel backhoe I have I may rebuild the gas motor or i still might rebuild the disel?
