Case1000 crawler dozer.
wayne
05-25-2001 21:44:59
just purchased what I'm told to be a 1000case crawler diesel. need to know what to look for ..for low oil pressure . seller said it always had 40 pounds cold and 30 lbs hot then all of a sudden it dropped to 10 -12lbs , no knocks either tryed a new pressure gauge ..no difference,tryed new oil filter same results. Seller said he noticed it when he found his injector pump had come loose and broke one of the mounting bolts off. Is there any way for sure to proper I.D this unit ? the tags on eng, and cowl are so far gone that you can't make out the serial or model numbers? It says case cleatrax-o-matic in a medallion on frt grill. There are HI-N-LO FOR BOTH STEER HANDLES. plus two more handles coming out of cowl with the same HI-N-LO. The tracks have 4 rollers on bottom and two support rollers on top.Tracks are 12-13 inch wide , there are two brake pedals to the left on floor, plus a gas pedal on right. Any help would be appreciated please respond to wmkolo@cybrzn.com...Thanks!
