Reliable source for J D 350 Reversor Parts
wingnut
12-28-2003 08:30:09
Rebuilding a 1967 JD 350 reversor,Need friction Plates and seperator plates along with bearings,Looking for reliable source for parts. Thanks Wingnut
jdemaris
12-29-2003 06:28:14
 Re: Reliable source for J D 350 Reversor Parts in reply to wingnut, 12-28-2003 08:30:09
You can buy the bearings from almost any bearing dealer or wholesaler. They're just plain-old adjustable cone bearings and races. As for the clutch disks and steel plates, as I recall, they're made by Twin Disk Company. I don't know if you're going to buy them anywhere cheaper then through John Deere though. When I worked as a Deere mechanic, the best bearing buys were right through Deere, but maybe things have changed. When putting your reverser back together, make sure the main-shaft bearing endplay is done with a dial indicator. It's critical, and just about impossible to adjust by "feel." Also, make sure the oil orifice is clear in the powershaft.
wingnuts
12-29-2003 07:37:57
 Re: Re: Reliable source for J D 350 Reversor Parts in reply to jdemaris, 12-29-2003 06:28:14
Thanks JDE...As you have helped me in my decision to tear it down instead of just replacing the seal..I have about 4 friction discs to replace and five seperator plates to replace,the seperator plates look like they got pretty hot as they are blued in color,..thanks once again Wing
