How do you remove the hand clutch release shaft on
Rick from Paso
12-28-2003 19:11:23
I have the cover off, the connector assemby unbolted and the grease fitting out, how do you drive out the hand clutch release shaft that operates the release fork on the clutch? It seems that there is not enough room on either side of the frame unless I remove the body somehow (lots o work). Anybody replaced a clutch in a TD6 (or TD9) before? Thanks for your help in advance!
captain crunch
12-28-2003 21:21:24
 Re: How do you remove the hand clutch release shaf in reply to Rick from Paso, 12-28-2003 19:11:23
Rick come over to red power there is a fellow doing the same thing. look for post about TD-6 and check out the pictures and book views. Just click on the link in KoO's note above Brian
king of obsolete
12-28-2003 20:08:59
rick, i do it on my older td-9s. there are bolts on the cutch fork you have to remove plus the keys on the shaft where the fork is. then remove the clutch handle by looseing the bolt and spreding it with a chisel. then use a jack all and lift the passenger track and now use a smaller shaft and tap the shaft out from the driver's side. we can post pictures at redpower so join us there Link thanks
Rick from Paso
12-28-2003 23:10:24
 Re: Re: How do you remove the hand clutch release in reply to king of obsolete, 12-28-2003 20:08:59
Does that that mean I must remove the fenders and fender side sheets too? BTW I went to the Red power site and looked for info there but didn't see it. Thanks for your help King of Obsolete.
king of obsolete
12-29-2003 05:16:59
 Re: Re: Re: How do you remove the hand clutch rele in reply to Rick from Paso, 12-28-2003 23:10:24
rick, come and start a new post, and then we can post pictures and pages from the manual. jim is right, there is holes in the sheet metal and don't lose the keys (keystock) thanks
JimInOz
12-29-2003 01:17:41
From memory,I think there's a hole for the shaft to exit thru in the side panel.Watch those woodruff keys when you re-install shaft....don't lose them...you have to watch them as shaft re-inserts.
