D3B
jimtex
12-30-2003 22:06:51
Can somebody tell me what YEAR model these 2 D3's are????? ?? Serial #27y02247 and 27y0987. I'm beginning to think someone's messing with me. Thanks. Jim
jimtex
01-21-2004 09:17:22
 Re: D3B in reply to jimtex, 12-30-2003 22:06:51
Thanks, Steve. These are not for sale (at least not right now). The 0987 belongs to a buddy, and when he bought it, they told him it was an '88 model. When I bought mine (02247) as an '84, it just didn't seem right. Do you happen to know if D3B has an adjustment on steering clutches? And if so, how to do it? Thanks again. Jim
Steve
01-21-2004 14:15:01
 Re: Re: D3B in reply to jimtex, 01-21-2004 09:17:22
There should be a panel on the back of the machine,but I've never adjusted a d3 personaly i wouldn't atempt it with out a manual or asking someonewho has done it
Jeremy
06-20-2004 21:31:19
 Re: Re: Re: D3B in reply to Steve, 01-21-2004 14:15:01
I'm not to sure about the D3, however the D3b I am. I have a D3b-LGP and on my machine it's a fairly easy, yet time consuming job. If you remove the seat and cover plate, you should see all your pedal controls. If you look about halfway back on the left and right side you should see 2 plates that look oval with 2 bolts on each holding them in place (I know 1 is almost under the hydraulic tank). Remove 1 from each of them and loosen the others. Spin the plates out of the way. You should see a shaft that has a 6 point bolt head (You may need a flash light).You'll need a 9/16 socket and an extention. Now, how, I've been adjusting them is tighten them down then back off 2 full turns. The manual may say different so I'd double check that adjustment. Oh, 1 thing to add be sure your socket locks on to your extentions, seems people like to lose sockets in those chambers. Remember my settings aren't by the book so I'd call a cat repair center to double check, also I have a D3B-LGP, with wet brakes. That might make a difference.
Wendell
08-30-2004 06:07:24
 Re: Re: Re: Re: D3B in reply to Jeremy, 06-20-2004 21:31:19
How much force is required to turn the adjustment on the brakes? I tried with a small 3/8 rachet and could not budge them one way or the other.
Steve in NJ
01-18-2004 10:56:07
2247 is a 1984 d3b other is 1980 d3b are they for sale
