jd 45 motor in a crawler
nathan bolzeniu
01-01-2004 07:54:21
I have a very good motor out of a john deere 45 combine (round back). Can anyone tell me what size crawler the motor will fit in. I have heard it is the same size motor as a 1010.
440Sam
01-02-2004 06:53:38
 Re: jd 45 motor in a crawler in reply to nathan bolzenius, 01-01-2004 07:54:21
The 4 cylinder gas engine from a "round back" combine is a 145 ci power unit that is the same engine as the 2010. The engine will bolt into a 1010 however the gas 1010 has a 115 ci power unit (same as a 40 combine). Look on the left front side of the engine block and you will note that they all have the same casting numbers. Hope this helps.
