Case 1150 H trans. oil blowout
david
01-03-2004 22:51:22
On a case 1150 H with 515 hours, if you run it in low everything is OK, if you use hi-range its still OK. If you engage the button on the shifter that makes the "running rabbit" light up on the dash, it will force trans. oil up and out the fill tube. Gauge never shows hot at all. When you click the button the engine will load up a little, even with the trans. in netural, like its in a bind somehow. Have changed the oil and filters twice and still the problem persists. Finally took the relay out and the problem stopped.I know this doesnt fix anything but at least the oil stays put. Bought it 2nd hand and cant find out if warranty is transferable the the 2nd or 3rd owner.What is the warranty period on a machine this new? Its a 2002 model. Any help is greatly appreicated. Thanks, David
