jd 310c backhoe
td-9
01-08-2004 20:59:14
looked at a 310c 2wd 4in1 bucket backhoe today "93? model" . Very tight, no! blow by exahaust clean, enclosed cab, removable windows,no ac, "no leaks?",new front tires, good rear tires, Quick disconect bucket,city machine,paint o.k. been sitting under trees so alot tree junk on it, everything works-rotating light and front and rear lights,one weld on 4in1 cylinder top mount, one on bucket mount,no history. wondering the price $10,000 cash $14,000 company check. So what is this machine really worth or this to watch out for on a 310c? thanks for your time and knowledge.
Jonathan
01-09-2004 16:12:59
 Re: jd 310c backhoe in reply to td-9, 01-08-2004 20:59:14
Not a bad machine...check the usual...excessive pin/bushing wear...engine condition (oil in water or water in oil)...check the reverser for slipping...smell the reverser oil to see if it smells "burnt".....other than that , just look for the obvious...10,000 is a decent price...4x4 is more desireable ...but if not needed then no big deal....older machines go for the same price so..sounds like it would be worth it....even more if the condition is good..
