Anderson straight blade accessory
Polk Crawler
01-09-2004 09:10:03
Would like to locate the attachment that allows angling an Anderson straight blade used on an OC3. Have seen pics of this; blade frame has extra holes to accommdate such an accessory. Will appreciate any leads. Thanks PC
jdemaris
01-09-2004 18:50:10
 Re: Anderson straight blade accessory in reply to Polk Crawler, 01-09-2004 09:10:03
I've seen quite a few Anderson blades on Cletrac HGs and OC3s that permit use of spacer to angle the blade a bit. If that's what your talking about, it's pretty easy to make. You are talking about the blade that is held in by two large pins, one on each side of the blade? Depending on which side you want to angle out, you pull the oposite side pin out and stick in the spacer. That's the setup mine had but I changed it over to a hydraulic-tilt. If you don't want to make the spacer, it's likely Zimmermans has a used one.
:Polk Crawler
01-09-2004 22:10:09
 Re: Re: Anderson straight blade accessory in reply to jdemaris, 01-09-2004 18:50:10
jdemaris: answer is y es, you described it better than I. I have no capability of making the spacer so will check with Zimmerman. Thanks for the reply. PC
