POWER STEERING PUMP
ED
01-09-2004 09:15:18
I have a TCI loader it is ford powered with a 172 ford tractor power plant the trouble is the ford power steering pump . I was woundering if anyone knew of a replacement it is same pump as ford 600-800 tractors and someone said ford cars and trucks used them does anyone know of or had experience with this Thanks ED
Roland Jackson
01-10-2004 06:01:27
 Re: POWER STEERING PUMP in reply to ED, 01-09-2004 09:15:18
Hi Ed I am involved in power steering for Ford Tractors. Only a few parts are still available for the 600-800 steering pump you are wanting. I use a priority valve, manufactured to work with the power steering systems I build. It would be easy to install and would last you a life time. I have several different configurations...from set flow to adjustable. The priorty flow valve would be the perfect fix to your loader's power steering system.
Rodger Beaton
06-25-2005 16:54:52
 Re: Re: POWER STEERING PUMP in reply to Roland Jackson, 01-10-2004 06:01:27
I'm interested in obtaining a steering priority valve? do you have any info? part numbers?
I put a newfield steering ram on a case Di. it has a large crankshaft pump and a great big loader, so I have plenty of pressure.
thanks rodger
