int. td6 fireing order
RICHARD
01-11-2004 12:48:11
I have td6 around 1946 I think. the price was right as it was free if I would haul it out of north Fort Worth Tx. IT has set for 17 years and was quite a challenge getting it home. I have freed most ever thing up and ready to start on cranking the engine . Most all 4 cyl engines fire 1243 but I know absolately no nothing about diesel engines. IF it is stamped somewhere then it must be covered with greese. Would like to communicate with someone who has done this before. appreciate any information. richard in tx
Mark in AB
01-11-2004 19:33:28
 Re: int. td6 fireing order in reply to RICHARD, 01-11-2004 12:48:11
Most all 4 cylinders and your td6 fires 1342. Makes no difference if gas or diesel. besides your td6 starts on gas anyway. Double check which directions your ignition rotor turns and set firing order accordinally from #1 mark on cap.
Bob
01-11-2004 17:21:38
Richard, if you've done all this work without a manual and think that the firing order on most 4 cylinder engines is 1234 stand back when you start this thing..... ..Safety 1st..... Good luck
RAB
01-11-2004 13:21:30
Richard, You could always check by looking at valve gear while turning engine slowly. It will reveal all in a few rotations. Regards, RAB
king of obsolete
01-11-2004 14:55:46
 Re: Re: int. td6 fireing order in reply to RAB, 01-11-2004 13:21:30
this is what a td-9 is and that should be the same, didn't have time to look thru the manual for td-6, 1-3-4-2 thanks, if i'm wriong some one will say for sure.
king of obsolete
01-11-2004 13:19:58
come and join us at redpower, there is lots on the td-6 and i'll get the firing order for you, ----- Link ----- thanks
RICHARD
01-11-2004 18:19:13
 Re: Re: int. td6 fireing order in reply to king of obsolete, 01-11-2004 13:19:58
Thanks for your info. I would order thr manuels for the td6 if wife would let me. All my toy money went into a 1952 jd mc so i will have to wing it on this tractor till times get better. Agin thanks for respones and I just posted on Redpower Mag. richard in tx
