need info on Oc-4 creeper trans/reverser?
glenn
01-13-2004 12:50:13
Im needing to know who manufactured the oc-4 creeper trans. I have located a creeper trans in an oc-3 but it doesnt look like it will work,due to the fact that the oc-4 trans is longer. are the revereser trans the same length as the creeper trans?? thanks for any help. GLENN
glenn.
01-14-2004 12:39:54
 Re: need info on Oc-4 creeper trans/reverser? in reply to glenn, 01-13-2004 12:50:13
Thanks for all the info.Im going to try to put the creeper trans in my Oc-46
jeff
01-14-2004 04:53:23
Glenn, If it really is a creeper you found i an oc-3 I would interested in it if you were not. I'm located in Pa. so we would have to arrange something. thanks, jeff
jdemaris
01-13-2004 14:29:20
Creeper trans. in an OC3 is totally different from a creeper trans. in an OC4. OC3 used a kit sold by Oliver but made in CA that used a Ford Model A speed. OC4 used what Oliver called the "Slo-Lo" aux. trans. It was an option with two speeds. An OC4 could also be ordered with a "Travel-Reverser" aux. instead.
GLENN
01-13-2004 16:05:55
 Re: Re: need info on Oc-4 creeper trans/reverser? in reply to jdemaris, 01-13-2004 14:29:20
Thanks for the info on the slo-lo aux trans. were can i get a picture of this trans. I am located in california. I have located several junk tractors with aux/reverser trans. I just not shure if they will work in my oc-46. thanks GLENN
jdemaris
01-14-2004 05:31:32
 Re: Re: Re: need info on Oc-4 creeper trans/revers in reply to GLENN, 01-13-2004 16:05:55
I've seen quite a few on the OC4s with aux. and with reverser (either-or) but have no photos -just the owners manual, sales brochure, and spec sheet. I've got a couple of HGs and an OC3, and I DO have photos of the aux. setup for them. A friend of mine has a complete factory setup (off tractor) sitting in his garage. I have photos of that too. It was made by California Specialties and sold by Oliver as an option. OC4 has a different engine, clutch, and driveshaft. I assume the SAE engine to clutch-housing flange is the same with the OC3 Hercules IXB3 engine and the OC4 three cylinder Hercules (gas of diesel) but I wouldn't swear to it. You could make the OC3 aux. work on an OC4 but it would be a lot of work.
bill
01-14-2004 20:20:34
 Re: Re: Re: Re: need info on Oc-4 creeper trans/re in reply to jdemaris, 01-14-2004 05:31:32
hey guys I also need a reverser for an OC46 aso may buy a moter rather than rebuild mine 406 827 3006
old
01-13-2004 13:16:26
Give Mr. Zimmerman a call he will probably have one and also be able to tell you if the one you found would work 717-738-2573
