Info wanted
Brian
05-30-2001 16:18:31
looking for info on following crawler. Cleatrac model MG-1 with rubber coated tracks, winch,generator,compressor,tank assembly,2 pintle hitches. this all looks to be original possibly used by millitary on runway? any help is much apprec
Pete
06-05-2001 18:12:35
 Re: Info wanted in reply to Brian, 05-30-2001 16:18:31
This info from Bart Vanderveen "Historic Military Vehicles Directory" - Cletrac MG1 was a high speed 7-ton tractor. Six cylinder, 137 brake horsepower engine (Hercules WXLC3 - 404 CID) driving rear sprockets via 4 speed gearbox. Controlled diferential steering. Mechanical brakes. Track width 14 in. Volute spring suspension. Front mounted 5-ton winch. Overall dimensions - 170X70X68 in. Weight 14,915 lbs. Standerdized in 1941, more than 8,500 were built until 1945. They were used by the Army Air Force (and RAF) for towing heavy aircraft and equipment. I think Paramore junk yard in Mt. Pleasant Fla. has one of these stuck back in the trees. Hope this helps!
