TD-6 I Need Help
Tara
01-16-2004 16:48:22
I was willed an old TD 6 from my Granddad ,When I got it home and started it it ran ok some missing. But it sprays oil out of the exhaust pipe. No white smoke just oil.Any ideas? Thanks
swedeguyTD9
02-20-2004 13:42:55
 Re: TD-6 I Need Help in reply to Tara, 01-16-2004 16:48:22
It could be a stuck oil ring on one or more piston, or worn valve seals. Could also be unburned diesel fuel, I had a ignition miss at my TD9, I adjusted the valves and that cured my problem. /Dennis
clark
01-16-2004 21:03:18
if its been setting a long time then there may be a exhaust valve stuck open. this will cause it to not fire the diesel fule in that cylinder causeing it to blow out excess fuel. if it isnt a stuck valve then its mostlikeley a cracked head.
king of obsolete
01-16-2004 17:44:49
come over to red power, lots of td-6 there and pictures too, ----- Link ----- -thnaks
rod
01-16-2004 17:41:55
tara where are u located if you decide to sell it?
